3cx Convertor
Keith Gauci
Forum User
Hi, I followed the documentation to convert Freepbx to 3cx:
https://pbxservices.3cx.com/config-converter &
https://www.3cx.com/docs/free-pbx-converter/
My issue is that when I backed up the Freebpx the compressed .tar file size is around 250mb while the converter only accepts up to 100mb.
Is there any solution to this?
I tried removing the sounds folder and even splitting the file in multiple compressed files, thinking that maybe I can put everything together after the conversion, but all of them were corrupted.
Thank you
Hello @Keith Gauci
Did you include the files mentioned in the guide in your backup or did you include additional files? If you did then try creating a new backup with only the mentioned data and see if that is below 100mb
Hello @Keith Gauci
The above are the files I included in the back up (As in the documentation). I tried to exclude the sounds folder but without it the conversion failed.
