Solved 3CX Country Blocking Feature
jorgemichel
Hello team I need help I can not call this callsign below you can help me on the portal I have this error below.
Call from [104] to [00221338226703] has been rejected by the 3CX Country Blocking Feature [00221]. Reason: 00221338226703 contains Prefix 00221. Calls to 00221 are not allowed by system. Resolution: To allow th
You need to make changes to allowed countries - under Settings, Security,
Reactions: EniPort
Is it For Senegal country?
tick this
13065
Under Settings > Security > Allowed country codes, you will find the setting you are looking for.
Enable traffic for this country code and you will be allowed to proceed
Thank you so much it worked perfectly
Reactions: JohnS_3CX
Glad to hear, thanks for confirming.
Kayla Norris
