3CX CRM API Filter by number if digits
TecMate
I'm about to start a project using the new(er) 3CX CRM API documented here
https://www.3cx.com/docs/crm-integration/
However I cannot find any way to filter calls by the number of digits.
i.e. don't run CRM if the call is an internal call or less than 4 digits.
This was an easy option using the old CRM integration plugins:
Am I missing something? Because my client would go crazy if all their internal calls pop up a CRM window.
Internal calls do not query the CRM.
Reactions: edossantos
lastshadow
