3CX Crm Intergration PhotoUrl
Alle CTEC
I can't find any instructions on how to pass the contact's photo to 3CX. I mean, size, format and path. Can the file be available in a web location or must it be uploaded to the 3CX folder beforehand?
Thank You
Thank You
The value isn't used so the Output for that is unnecessary.
You can't add the contact photo through a CRM template. This can only be added to local contacts through the console.
I don't need to display an image for each contact; a different image would help differentiate between contact types. If I copy some images locally to the PBX and pass the path as the PhotoUrl, will the image be displayed? Thank you
Ho provato a caricare un photo contatto utente rubrica da console 3CX, ho visto che vengono salvate in /var/lib/3cxpbx/Data/Http/wwwroot/user_images quindi ho verificato formato e dimensioni ho caricato la foto nel percorso /var/lib/3cxpbx/Data/Http/wwwroot/user_images configurato permission phonesystem:phonesystem come altra foto provato a passare come PhotoUrl /var/lib/3cxpbx/Data/Http/wwwroot/user_images/photo.png ma la photo non viene mostrata
I found another post regarding the PhotoUrl where it is indicated that the field exists but it does not work in the sense that it is not used. In fact, I tried to export the contacts and the field is not mentioned even though it is present.
Kayla Norris
