3CX CRM Template Generator request content error
alexis.berindei
Hello all!
I'm trying to connect 3CX with Odoo by using a self developped plugin in Odoo to expose contact in order to process the contact lookup.
I build two scenarios:
- the first one is authentication (json post to given URL)
- the second is the matching scenario.
But the main problem is on authentication:
here is my request content:
{"jsonrpc":"2.0","method":"call","params":{"db":"[Database]","login":"[UserName]","password":"[Password]"}}
here is the request content build by 3CX (same things in 3CX CRM Template Generator and 3CX Server):
{"jsonrpc":"2.0","method":"call","params":{"db":"db_fake","login":"login_fake","password":"password_fake"]
The double }} is replaced by ]
Any idea ?
Have you tried moving part of it? The order doesn't change anything so I would try it like this:
{"params":{"db":"[Database]","login":"[UserName]","password":"[Password]"}, "jsonrpc":"2.0","method":"call"}
See if the }} is still replaced by ] since there's no }} like this.
Yes, that's a standard replacement done by the CRM engine when interpreting the expressions. This is because the characters [ and ] are used to start and end a variable placeholder, so the way to change that is using {{ or }}. This is explained here:
https://www.3cx.com/docs/server-side-crm-template-xml-description/#h.2oikrv8ncny6
In your case, you should add a space, and that will fix the issue:
[B]{"jsonrpc":"2.0","method":"call","params":{"db":"[Database]","login":"[UserName]","password":"[Password]"} }[/B]
Thank you very much, it's working well !
Thank you for this documentation edossantos
Reactions: edossantos
awan05
