- Joined
- Mar 7, 2019
- Messages
- 13
- Reaction score
- 4
I am using the 3CX Template Generator to create an integration with Maximizer CRM. Due to the way Maximizer works, I need to request an authentication token to be used for each lookup of the address book. Both requesting the token and address book lookup require a HTTP POST so I am using the 'Matching Scenario' to do this, I can get both parts working independently, but when I try and use 2 'Matching Scenario's' in the generator it just doesn't work at all. Question is, should this work or am I trying to do something that's just not possible? I wondered if it was a limitation of the test tool in the generator? I have already found that if I give the Matching Scenario a custom ID (other than the default "") then it doesn't work either.
Any advice gratefully received
Nick
Nick
