Solved 3CX Debian installation hanging after entering domain name
zhongjie
Google is proving fruitless unfortunately. The ESXi is v6.0 and try to install the latest 3CX v16.
Anyone come across this issue before? Works completely fine on a 6.7 ESXi
EDIT: It appears you need an internet connection even during the install as it downloads a preconfig file from 3CX servers.
Hello Zhongjie,
I've checked and seen that ESXi v6.0 is no longer supported by VMware as of March 12, 2020. May I suggest updating to the latest version, which worked well for you in the past then trying again?
Hello Zhongjie,
I found out the issue, we were installing in a contained DMZ without internet and 3CX needs to download a config file during the install.
Reactions: VasilisV_3CX
Great to hear! That is correct, during installation you require access to the activation server. Glad you have it working now.
intoxtech
