Solved 3cx Debian update killed 3cx server
Big-Foot
Somehow the auto update function didn’t do as expected and mailed the following
E: dpkg werd onderbroken; voer handmatig 'sudo dpkg --configure -a' uit om het probleem te verhelpen.
Rollback to 15.5.10244.4...
So as suggested i did this command. Now this failed somewhere around the Mono DB.
And now login is available anymore.
So as a not Debian user what now?
Fixed it. Did a reinstall seems to work perfectly now
Glad to see the issue has been resolved and thank you for updating the thread with your solution.
