3CX Debian V20 Free - UPS installation
AlekosK
SOHO User
Hello.
Just finished with the 3cx Debian V20 (Free). Had 3cx v18 on Windows, but since the free edition for Windows will be over in few months, did install the Debian v20. So far so good.
One question,, if somebody can assist. Need to install the well known apcupsd for the system to shut down in case of power failure.
Unfortunately it is not in the repository(ies), neither nut.
Any assistance/advice is more than welcome.
Thanks in advance.
Alekos
Anybody ? No one uses UPS's ? Need to connect to UPS' NMC thru SNMP.
My other Linux machines are connected.
Many thanks
3CX does not have many common tools in their repos. This is someone you will find elsewhere on the forums as well.
You either modify the sources list (unsupported) or you run without it (supported).
tom.walker@blackcountryra
