Solved 3CX Deployment to AMZ LightSail
Eugene EBS
Gold Partner
Please add the options below for 3CX deployment:
  • Option to Change the name for the Instance on Amazon Lightsail (it automatically creates the name like that: amzls-custom-ca-central-1-2021-08-25-17-02-36-pzgye30y1.....)
  • === To change name on Amazon Lightsale - I have to backup instance and redeploy it with new name - which is not convenient, and takes time
  • === The same thing with Static IP - it also needs to be deleted and created again with new name
  • Option to change administrative port 443 to 5001
Thanks!
Reactions: QCS-INF
@Eugene EBS thank you for the feedback, yes we can understand your point.
We will check this internally with the Developing Team !! :)
GP Concepts
