3CX Desktop App - context menu placed wrong
VSC
Forum User
If I try to open the context menu in the new 3CX Desktop App of a user who is listed at the bottom of the userlist the menu is not shown completely. Thus some buttons are not cklickable. You should ensure that the menu is always displayed completely.
Hi @VSC,
Thanks for posting this. We're aware of this, and we're currently working on a fix.
Reactions: VSC
If you want another small cosmetic issue, at least in app v18.7.7 in the chat screen the "Forward" arrow covers the checkmarks in the chat so the tooltip can't show. It can just barely work for a double checkmark but the single checkmark is covered by the dropdown arrow. I was trying to remember what a single check meant yesterday and couldn't get the tooltip to show. :)
Same when we try to select text, the cursor keeps selecting the forward button menu.
Hi @SteveITS and @ConceptsWeb,
I see what you're saying, but bear in mind that this worked the same way as in v16. I don't think this is a bug, as the visual representation is clear enough I find, grey single tick when sent but not seen. Blue double ticks when seen. I get that this can be more clear with tooltips but then I'd suggest adding it as a feature request.
megalmazan
