3cx Failover Server
HS-ITops
Dear Team
To Setup Secondary Server,
  • Do We need to Install by using same License/FQDN and then later Enable Failover and Schedule Restore?
OR
  • We need to Restore from the Backup file of the Primary Server and proceed for Failover Configuration?
I have some great news!
There is a comprehensive guide available that details everything you need to know about FailOver. Did you consider doing a little research before starting a discussion thread? :)
https://www.3cx.com/docs/failover/
No matter the method you use, the important thing is the final result.
Two (2) 3CX PBXs each with its own public IP, both installed with identical settings, including FQDN, SSL Certificate, SIP, Tunnel, web server ports and operating system.
yes , both is fine
Reactions: HS-ITops
DrunkeMeister
