3cx FQDN security question
Prawnapple
Platinum Distributor
Intermediate Cert.
Hi There,
Is there a way for this page to not display when trying to access the 3cx FQDN? I understand it may have something to do with certificates?
That message means the address you used to access that web page does not match the SSL certificate installed. Typically you would see this if you used the IP address or some other name that might resolve to 3CX instead of the actual FQDN.
Thanks a stack
gmacinit
