3CX Generating a bad Patton SN4112 Configuration file
bdgarcia
I have generated a configuration file for a PATTON SN4112 FXO gateway. I cannot get the auto upload to work, but I have been able to manually upload via the Web Console. After it reloads I get these errors:
Waiting for Ethernet link (PHY:0) .... done
Waiting for BOOTP information ................Can't get BOOTP info, using default IP address
Ethernet eth0: MAC address 00:a0:ba:10:62:7b
IP: 172.16.40.1/255.255.255.0, Gateway: 0.0.0.0
Default server: 0.0.0.0
RedBoot(tm) bootstrap and debug environment [ROM]
Version v2_0_1 - Built 08:49:35, Oct 13 2017
Copyright (C) 2000, 2001, 2002, Red Hat, Inc.
SN4112/JO/EUI (MPC870 @ 65.536000 MHz)
RAM : 0x00000000 - 0x02000000, 0x00025678 - 0x01ffd000 available
FLASH: 0x60000000 - 0x60800000, 128 blocks of 0x00010000 bytes each.
Press ^C to abort boot script, press enter to start immediately
Executing boot script in 1 seconds
RedBoot> fis load
Loaded 2802108 bytes from 0x60040008 to 0x01800100 (entry 0x01800100)
RedBoot> go
Starting 'Firmware R6.9 2017-03-13' at 0x01800100 via 0x01800100
System type is SN4112/JO/EUI, 0004-0004
Serial No. 00A0BA10627B
Proceed with standard boot.
Checking PLDs...
Planar board : checking - please wait (this may take some seconds)
PLD OK, Version = 0x00040103
Installing Drivers...
Ethernet 0/0, MAC Addr 00:A0:BA:10:62:7B, RxQ 32, TxQ 64
Starting Modules...
2020-07-11T06:02:15 : Target Shell
All modules successfully started
Config startup-config READ [ OK ]
Config startup-config EXECUTE 2020-07-11T06:02:44 : LOGWARNING : Errors in configuration of router 'switch' ('show call-router switch reload' for details)
2020-07-11T06:03:06 : LOGINFO : Link up on interface ethernet 0 0 0
2020-07-11T06:03:07 : LOGINFO : Link up on interface IF_IP_LAN
[FAILED]
2020-07-11T06:03:14 : LOGWARNING : Config: Line 19: SN4112/JO/EUI(ic-voice)[0]#sntp-client
2020-07-11T06:03:14 : LOGWARNING : Config: % ^ Keyword mismatch
2020-07-11T06:03:14 : LOGWARNING : Config: Line 21: SN4112/JO/EUI(ic-voice)[0]#sntp-client server primary pool.ntp.org
2020-07-11T06:03:14 : LOGWARNING : Config: Line 220: SN4112/JO/EUI(prt-eth)[0/0]#port ethernet 0 1
2020-07-11T06:03:14 : LOGWARNING : Config: % Ethernet port does not exist
2020-07-11T06:03:14 : LOGWARNING : Config: Line 238: 192.168.57.13(prt-fxo)[0/1]#port fxo 0 2
2020-07-11T06:03:14 : LOGWARNING : Config: % Port 2 on slot 0 does not exist.
2020-07-11T06:03:14 : LOGWARNING : Config: Line 244: 192.168.57.13(cfg)#port fxo 0 3
2020-07-11T06:03:14 : LOGWARNING : Config: % Port 3 on slot 0 does not exist.
2020-07-11T06:03:14 : LOGWARNING : Config: Line 253: 192.168.57.13(ctx-cs)[switch]#no IF_FXO_2
2020-07-11T06:03:14 : LOGWARNING : Config: Line 254: 192.168.57.13(ctx-cs)[switch]#no IF_FXO_3
2020-07-11T06:03:14 : LOGWARNING : Config: Line 259: 192.168.57.13(ctx-cs)[switch]#port fxo 0 2
2020-07-11T06:03:14 : LOGWARNING : Config: Line 261: 192.168.57.13(cfg)#port fxo 0 3
Opening Modules...
All modules successfully opened
System is up.
2020-07-11T06:03:16 : LOGINFO : Warm start.
I have it getting it IP configuration using a static DHCP reservation. The unit seems to work fine until I upload the config. Once I upload the config, the IP configuration appears to be lost, and I have to factory reset. Once I factory reset all is fine until I upload the configuration the unit is hosed again.
I have attached the configuration file in case that gives any clues.
I am using the 6.9 firmware for the Patton.
I remember when I setup my 1st 4112 it is was a NIGHTMARE, and it seems 9 years later nothing has changed. :(
Any help is greatly appreciated.
I am also running the late version 16 3CX software for Windows.
Perhaps help from a Patton expert as @eddv123 may help you to fix
The IP configuration side of things can be confusing at times however your file clearly states that your WAN interface is on DHCP and LAN 192.168.57.13 with a class C subnet.
If you use Advanced IP scanner on your local network does it pick up the Patton ? what if you swap ethernet cables into the other physical ethernet port (I am assuming your model has a second port).
https://www.advanced-ip-scanner.com/
Also regarding the configuration upload (as per the below) this requires manual upload to the Patton's interface and cannot be done in an auto-configuration fashion like the phones: https://www.3cx.com/voip-gateways/patton-smartnode-sn4112/
I am not sure why you are seeing those error lines however your configuration and firmware match what they should be to work.
Wecare_ITA
