3CX Hosted and Compatibility for Loud/Office Ringer and PA
Chris Wheeler
Gold Partner
I have a client who would like to move to 3CX Hosted. They have three locations that would be part of the system.
One location currently has a Loud Ringer (Algo 8180) and another location has a Snow PA1 that ties into their paging setup.
It looks like the Snom is no longer supported behind the SBC as of v18 and I was going to replace the Algo with a Cyberdata Office Ringer, but that also is not supported behind the SBC in the hosted setup.
I wanted to see if anyone had suggestions for alternative options for these two scenarios on a 3CX Hosted setup.
As far as the ringer is concerned, if you are unable to find a SIP device that works for you, you might consider a supported ATA, coupled with any "regular" analogue, loud, signaling device, on the market. Availability/selection of these tends to be a bit more varied.
I don't have access to one at the moment, best to lookup the PA2 specs and manual to be sure it does what you want.
SupportRock
