3CX Hosted Time is off by 4 Hours
Keith Casteel
Hello, I have many Pro 4SC and 8SC instances setup on 3CX hosted and all instances that I check has there time off by 4 hours and time is set correctly for my time zone and has not been changed. Rebooting does not correct. I do not have access to your Debian Bookworm console so I can not correct this issue on your cloud hosted systems other than to change the time zone to incorrect -1 instead of -5 for US Eastern which I have not done yet. Please correct.
Where do you see this wrong time? What are the settings in System->Options?
English
-5:00 United States Eastern Time on all 3CX hosted instances.
I needed to look up a call log and I noticed it was blank, so i changed to previous day and there they where. I called into the system and the time showed off by 4 hours when looking at the current active calls from dashboard. I also saw this issue on another 3CX hosted instance. I have not checked them all. I rebooted one instance and same issue.
The system uses UTC internally but all times shown would be on the time zone you have set (or local time of the device for apps). I am checking on my hosted and the time is shown correctly for the time zone I have set.
Reactions: paulodagraca
LeeonLau
