Solved 3CX - Instance Manager Automation
Bavesh
Dear All
I would need any help from you guys.
We are currently deploying the 3CX VM using the setupconfig.xml file with the partner ID included in the XML.
We would like to automatically activate the Instance manager features for the following :
1. Allow remote management of this pbx
2. Remote Management - Grants ability to local operations, such as restarting of services.
However we are unable to see these parameters in the XML. Is there any way to automate this in the cloud-init file.
Also is there any official documentation for all XML tags that are accepted as part of the setupconfig.xml. e.g. BACKUP, SCHEDULE, PARAMETERS, Mail Template etc..
Thanks in advance for your assistance.
Dear All
Not sure for the Instance Manager, but here's the docs: https://www.3cx.com/docs/configure-pbx-automatically/
@Bavesh because data is being shared with Instance Manager to the partner account, we didn't include this option on purpose and the user or admin of the PBX must enable it manually.
GP Concepts
