3CX integration with zoho crm
mohamed.saber
hello, i hope everyone is fine
i integrated 3CX with Zoho crm, it's authorized and tested.
i don't know how to configure integration on the end user level, how to enable pop up a new tab redirects to crm ?
In the Web Client > Settings > Integration > Set the option to use the server side integration.
You need to enable this option:
thanks, what next ? should i do something more ?
You should see the popup when you have a matching contact. Ensure that contact matching is working. Also, if the popup is not working, check if the browser is blocking popups.
this type of integration works for both ways or only inbound calls ?
For both, inbound and outbound calls.
Hello, I don't see that screen. Is this because I have another plan?
Thank you in advance
Are you running 3CX SMB? Server side CRM integrations are not available there. You need a Professional or Enterprise edition, hosted by 3CX, self hosted or on-premise.
Daz1964
