Solved 3CX macos Catalina mic don´t work
vitor perez
Forum User
hello i have 3cx on mac catalina, i can call and i ear the other person but my mic don't work and is marked has allowed on the setings.
any ideas ?
I have also had similar problems with 3CX unsupported headsets.
But when I am using 3CX officialy supported headset it works as supposed to.
https://www.3cx.com/support/ ---> list of officialy supported headsets.
What headset are you using? And what port, USB or 3,5mm jack?
i'm using internal mic and speaker of macbookpro or earbuds from apple
did that but also didn't work and the permitions are all ok, and don't work
and sometimes don't makes the call
i have to reboot the pc, then make the call but no mic :(
hello Johns
i have installed but no sound and no mic it makes the call but i can´t ear and the other person don´t ear me.
any solucion ?
best regards
In your webclient, please go here to select your headset and microphone
When done, you can call *777 Echo Test and talk to see if you hear voice going to and from the PBX
ok all good thanks for the support :)
Reactions: JohnS_3CX
Glad to help!
Reactions: vitor perez
gmacinit
