3CX not Loading UI well
vincent Kavila
My 3CX has been loading like this for the last 3 months, anyone with any idea what could be the issue? I have tried reinstalling the PBX but still the issue persists:
Have you used your browser in incognito mode or used a different browser, to check if this is still the case?
Yes, I have even used a different computer, but still the issue is the same.
I am using
Version Number
18.0 (Build 312)
Is there any 3rd party installation on the PBX server?
Have you tried to re-install on a dedicated machine and check if you are still experience the same issue?
No, but the PBX has been running on that machine since 2021
We are not aware for any changes on the PBX server that can cause this issue. I would suggest first that your machine is up to date on all OS updates. Then try to re-install on a dedicated machine and check if the issue is still there.
OS is up to date. It's running on Windows server 2019. No recent changes on the server
Understood but i would suggest that you re-install on a dedicated machine and check if it is still the case. If so you might also consider opening a ticket to 3CX Support to investigate it further.
With a quick look the icons look to be a font that is loading characters via CSS:
.halflings-cog:before {
content:"\e019"
and
@font-face {
font-family:Glyphicons Halflings;
src:url(glyphicons-halflings-regular.a7f3fc7c8a58df82.woff2) format("woff2"),
url(glyphicons-halflings-regular.cb4a46019d995925.woff) format("woff")
Could something be blocking the font from downloading from your server? Or blocking the CSS?
Reactions: jed
Reactions: vincent Kavila
Bold move putting a VPN client on your 3CX server. If that's full tunnel, all it will take it a connect and you won't have a fun day.
I managed to resolve the issue
mazet
