3CX on Linux on AWS EC2 instance - 'Server error' on Console
Claudio Bizzarri
I've installed 3cx on a T2 class EC2 on my VPC on AWS: yesterday I've a lot of "Server error" on console, and with systemctl restart 3CXPhoneSystemMC01.service command error is gone.
I've tried to update to SP5 Beta, but today I've had this error twice.
T2 processor supports VXD.
Any hints?
This is results of systemctl status 3CXPhoneSystemMC01.service on system fault:
Code:
3CXPhoneSystemMC01.service - 3CX PhoneSystem 01 Management Console
   Loaded: loaded (/lib/systemd/system/3CXPhoneSystemMC01.service; enabled; vendor preset: enabled)
   Active: failed (Result: signal) since Thu 2018-06-07 14:11:50 CEST; 4min 51s ago
  Process: 6263 ExecStopPost=/bin/rm -f /var/run/phonesystem/management_console01.socket (code=exited, status=0/SUCCESS)
  Process: 6258 ExecStopPost=/bin/rm -f /var/run/phonesystem/3CXPhoneSystemMC01.pid (code=exited, status=0/SUCCESS)
  Process: 641 ExecStart=/usr/lib/3cxpbx/ManagementConsoleJS --pid /var/run/phonesystem/3CXPhoneSystemMC01.pid -p /var/lib/3cxpbx/Instance1/Data/Http/webroot (code=kil
led, signal=KILL)
 Main PID: 641 (code=killed, signal=KILL)
Jun 07 08:07:05 ip-172-31-32-43 systemd[1]: Starting 3CX PhoneSystem 01 Management Console...
Jun 07 08:07:12 ip-172-31-32-43 systemd[1]: Started 3CX PhoneSystem 01 Management Console.
Jun 07 12:14:24 ip-172-31-32-43 sudo[4531]: phonesystem : TTY=unknown ; PWD=/var/lib/3cxpbx ; USER=root ; COMMAND=/usr/sbin/3CXSetTimezone Europe/Rome
Jun 07 12:14:24 ip-172-31-32-43 sudo[4531]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jun 07 12:14:24 ip-172-31-32-43 sudo[4531]: pam_unix(sudo:session): session closed for user root
Jun 07 14:11:50 ip-172-31-32-43 systemd[1]: 3CXPhoneSystemMC01.service: Main process exited, code=killed, status=9/KILL
Jun 07 14:11:50 ip-172-31-32-43 systemd[1]: 3CXPhoneSystemMC01.service: Unit entered failed state.
Jun 07 14:11:50 ip-172-31-32-43 systemd[1]: 3CXPhoneSystemMC01.service: Failed with result 'signal'
What size T2 instance are you running it on? T2.Small is probably the lowest you would want to run 3cx on
While I agree, that's most likely not the problem. I've had a T2.Micro run it with no problem for months
Yesterday I had three crash of MC. But I had a t2.nano, i believed that 512MB ram was enough.. So, this morning I've changed my instance to t2.micro (1GB ram), thank you very much for your comments. Let see if today works.
Ciao,
Claudio
gmacinit
