- Joined
- Feb 19, 2020
- Messages
- 15
- Reaction score
- 0
I manage 2 different PBX boxes hosted by 3cx. They are both running Version 20.0 Update 7 (Build 1080 Release).
Both are using the same VoIP provider (VoIP innovations) with the same VI server IP UDP port 5060. And both servers are set up the same on the Voip providers end (except for the recent FQDN change i mention later).
The trunks are set up as Generic SIP Trunk (IP Based) and the port on 3cx is set to 5060.
At the start of this issue both were using the same exact settings other then the 3cx server IP and the phone numbers.
One is working fine receiving calls and such.
The other stopped accepting requests from our VoIP provider. 3cx is not responding to the VoIP providers SIP Invites thus calls are failing to reach our server.
(Oddly direct lines are able to make it through on our VoIP providers Tertiary Inbound IP)
Since the issue, I have even gone and swapped pointing our endpoint from the servers IP to point at our servers FQDN with the IP being the backup.
I have gone through and set all of our VoIP providers IPs as allow in the IP blacklist in the admin console.
The server with the incoming issue is also unable to outbound calls through our VoIP provider.
The only warnings the event log shows is:
My only theory is that 3cx has a firewall that I am unable to control and they have blacklisted my providers IP addresses, except for the Tertiary Inbound IP.
| Unidentified Incoming Call. Review INVITE and adjust source identification: %1. | Warning | This is a problem when the Source is not trusted. 3CX expects SIP call traffic to come from a certain IP Address and with a certain format and fails to satisfy 3CX checks. For security purposes 3CX will not allow this request and show this message. |
| Call or Registration to %1 has failed. %2 replied: %3 | Warning | Check the reply from the endpoint. |
