3cx pbx on raspberry
saba
for migration purpose I try to set a PI 4 4go as 3cx pbx but it make me crazy ^^
the installation (latest) goes well, first web interface launch ok but after reboot some services won't restart.
i have those errors
Job for 3CXCfgServ01.service failed because the service did not take the steps required by its unit configuration.
See "systemctl status 3CXCfgServ01.service" and "journalctl -xe" for details.
A dependency job for 3CXSystemService01.service failed. See 'journalctl -xe' for details.
A dependency job for 3CXHotelModule01.service failed. See 'journalctl -xe' for details.
A dependency job for 3CXPhoneSystem01.service failed. See 'journalctl -xe' for details.
A dependency job for 3CXQueueManager01.service failed. See 'journalctl -xe' for details.
A dependency job for 3CXIVR01.service failed. See 'journalctl -xe' for details.
A dependency job for 3CXCallFlow01.service failed. See 'journalctl -xe' for details.
A dependency job for 3CXPhoneSystemMC01.service failed. See 'journalctl -xe' for details.
A dependency job for 3CXGatewayService.service failed. See 'journalctl -xe' for details.
A dependency job for 3CXAudioProvider01.service failed. See 'journalctl -xe' for details.
and
-- The job identifier is 2120.
Aug 29 08:24:34 raspberrypi systemd[1]: 3CXCfgServ01.service: Failed with result 'protocol'.
-- Subject: Unit failed
-- Defined-By: systemd
-- Support: https://www.debian.org/support
did I missed some thing ?
delaying boot to wait network ?
ok i tried on a other hardware with debian iso and it 's ok
the issue is that if a the first launch you select 1 for web UI and you don't end the UI configuration or restore at the next reboot the rasp didn't prompt for choosing 1 or 2 and the web UI is not available...
Just to confirm, you've successfully installed it and everything is up and running now correct?
To first clarify, are you saying that you started the web wizard and then rebooted before you finished the web wizard installation?
no migrated yet, planned this weekend
yes and when rasp reboot it didn't prompt the choice 1 ou 2
In that case, do not that you will indeed need to complete the installation once the installation wizard is initialized.
Do let us know how it goes!
when I ssh is there a way to launch the wizard 1 or 2 because I can see it in native session when a screen is connected but not when I log in trough ssh
Provided that you have not already gone through the 3CX Installation wizard or even attempted to initialize it then yes, you can try running the following command:
sudo /usr/sbin/3CXWizard --cleanup
Important: For anyone else reading this, please make absolutely sure that this command is not used on a Host on which the 3CX Installation Wizard has already been initialized. It also goes without saying that it should absolutely not be used on a Host already running 3CX.
laranicole.lucus
