3CX Phones system SIP Port change
selva
Dear Team,
Customer has 3CX V20 Update 10 with running configuration on 3CX Debian. And they want to change the SIP Default port(TCP/UDP) 5060 to custom port like 5066.(TCP/UDP) Currently I have full backup of 3cx phone system.
How do we change the 3CX SIP Port to 5066? Kindly share the procedure for the same and also share recommended SIP ports for 3CX Ports to avoid any internal 3cx ports conflicts.
Thanks.
Hi @selva, note that the PBX ports are set during the setup wizard, after the pbx is installed these ports can not be changed. If you already have a backup file, then proceed by deleting the current machine and deploy a new one. Then when uploading the backup you can set up the PBX ports to the desired one.
In this document you may see the list of the external ports used
Have a good day!
Have a good day!
Thanks for the details.
Without reinstalling the Debian OS , Can we rerun the wizard and restore the full backup and modify the SIP Ports?
I recommend spinning up a new machine using the latest ISO. During the setup wizard, you can upload the backup file and configure the new ports. The whole process shouldn't take long.
LVCC_Admin
