3CX PhoneSystem 01 SIP Server -stopped without warning
kseba77
A system that was running without a single issue for about a year (with restarts) suddenly had the 3CX PhoneSystem 01 SIP Server service stop.
A simple click on the service and clicking on start started the service without issue and now it's running again. The event log shows the services starting after I clicked start but nothing that would tell me why it stopped? Any idea where I could get more info about what happened and did something similar happed to any of you?
Running version 16.0.7.1078 in azure cloud
If you access the Azure instance via SSH and go to folder /var/lib/3cxpbx/ , in this folder do you see a file named "core"?
yes, I do see "core" in that folder. I also downloaded it hoping I can open it and see what's inside but it seems to be a binary file. What to do next?
Ok, a few basic question to understand your setup and how it was done.
  • What hardware specs have you give to the machine (vCPUs, RAM, disk space)
  • How many extensions/users are using it?
  • How did you install 3CX initially (Azure Marketplace, PBX Express, manually inserted the repositories)?
1. 4 vCPUs, 4GB RAM, 80GB Space, Linux based
2. 90
3. PBX Express
Hello @kseba77,
I'll lock this thread and PM you on how we'll proceed regarding this issue.
fransisco
