3CX PhoneSystem Database Server & Service Keeps Stopping and restarting
leyanu
Platinum Partner
Hello People,
I run a 512SC account on an AWS r5ad.4XLarge instance. Which I upgraded from a C5 instance
I have some robocalls and about 331 Extensions configured.
For the last 2 weeks, I have had the issue of my 3CX PhoneSystem Database Server & Service Keeps Stopping and restarting.
What can I do?
I have attached my system stat and a view of top users of my system resources
I need all the help I can get, the 3CX team isn't responsive.
I would start by having a look in the Debian logs to see if anything stands out for you - stick your PBX in to verbose mode.
/var/log/syslog
And can you confirm you've got nothing else running on this machine?
Hello @kieferschild ,
I do not understand much from the data in the syslog.
Would you mind I share this file in your DM?
Hi @leyanu,
Our Support team is currently investigating this with priority. Given the nature of the problem, Support is the correct department to be liaising with. As I understand it you spoke with someone from Support recently to find the best possible solution moving forward.
Hello @VasilisV_3CX ,
I have been speaking with support since last week and there has been no single pointer as to what could be the issue,
I have shared several gigabytes of files without any help,
I am stuck as not a lot is happening with the businesses I support at the moment
We understand both the gravity of the situation and the urgency and I can assure you that our support team is working with the dev team to get to the bottom of this.
If I can say though and slightly explain the delicacy of the matter, crash causes, especially on a system as busy as yours are not always the easiest thing to track down, especially if certain crash logs are retrieved a while after they were generated.
I am confident though from the little I read about the case that we are probably getting closer to the cause.
Reactions: ChrisC_3CX
megalmazan
