Solved 3CX Provisioning file - change ip
tobiastromm
You do not change the template.
Guessing phones are local to the 3cx server - Change the lan to the local IP address under the provisioning tab of the extension
No way to change it globally? Instead of change that on every extension?
Each device under each extension can be provisioned with a different provisioning method. So any adjustment to the provisioning method has to be done at the device level.
Thank you all.
I remember that is possible to select all extensions and click on Edit so it apply to all : - )
Reactions: YiannisH_3CX
GP Concepts
