3CX/SalesForce Integration Clarification
ih303
From reading previous threads on the topic, it is clear that the client-side version of the SalesForce plugin has been deprecated and is no longer supported. It is also clear that while the server-side plugin does not have the same functionality as the client-side, this functionality can be expected in v16. Do I have all that right so far?
Given that's the case, it's been mentioned that if we want to continue supporting the client-side version, we will need to run off of old builds. I need to be able to continue support of the client-side integration on new installs. Is there an official link to these old builds anywhere?
As an aside, are you guys still on track for the v16 release later this year?
Thanks in advance.
Yes, this is correct.
You can get the latest version we provided of the client side plugin from here:
https://downloads-global.3cx.com/downloads/v155/templates/integration/Salesforce.zip
Yes, we are. All the missing features will be available.
Kind regards.
