3CX-SBC IP from wrong interface
bradkuhl
I have SBC running on a VM that has 2 interfaces....one is used only for internal management of the VM from the hypervisor...10.1.1.XX and the other is the management network (10.10.100.XX) that the 3cx machine is running on.
When I log into the Admin Console under SIP Trunks and look at my SBC it has the eth0 interface IP not the eth1 IP address listed....
Where do I change which interface it is bound to?
Local IP is the IP that the SBC is using. The Public IP is the Outside network IP
Have you installed the SBC by deploying our ISO or did you use your own method of deployment?
What hypervisor were you using? Not all hypervisors are supported.
You want eth0 to be the internet facing side, not the other way round.
Senergia
