No, you have a "problem" because your customer uses the mobile app.I think it's the same problem as mine:
https://www.3cx.com/community/threa...p-the-call-with-the-smartphone-client.129190/
If the IP phone is not CSTA compatible, it will not work.
What IP phone are you using?
I've tried from a Polycom VVX 411 & a Yealink T46U.I think it's the same problem as mine:
If the phone wasn't csta-compatible (which is the case with many DECTs), it would be the same as my problem, hence my commentNo, you have a "problem" because your customer uses the mobile app.
This person is talking about the Webclient controlling a deskphone, not the mobile app.
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
