3CX Showing the wrong time
PaulCarter
Platinum Partner
I know this is probably something obvious that I'm missing.... but I have a 3CX on a Windows PC and it's showing the wrong time. The time on the PC itself is fine and the timezone is correct in the 3CX system settings but the time on the event log is showing as 19:40 when it's actually 11:40.
Any ideas how I could change this?
Hi Paul,
Is the PBX system installed on this Windows PC?
If so, can you check that the Windows timezone matches the one set in the management console?
Hi John,
Thanks for your reply. Yes the PBX is installed on this Windows PC and the timezones on both the PC and the 3CX are 00:00 London.
What version is your PBX and what version is your Windows host?
3cx is 16.0.504
and the host is Windows 10 Pro
The MC will dynamically re-adjust to the timezone on the PC from which you log into the MC (regardless of the PBX host time).
For example if a phone registers at 14:00 and I log in to a MC from a pc that has its time set to +2 then I will see the registration in the Event Log taking place at 16:00 in the event log.
saranga
