Solved 3cx Sim calls
Hostname
SOHO User
Hello i want to deploy 3cx with 512 sim calls i want to know how many extension to add?
and i want to know the hardware requirement depends of number of extension or number of sim calls because i want to install 3cx with 512 sim calls in HA
Did you see this...
https://www.3cx.com/docs/recommended-hardware-specifications-for-3cx/
You can add as many extensions as you like, it all depends on how they will be used, for how long (queues?), and the number of trunks you will use. If you had 1000 extensions, then they could all be on a call, to another extension, all the time. But that is not usually how things work, in the real world. Lots of variables to take into consideration.
ok thank you very much :)
We usually recommend 1 sim call per 3 extensions and we have a calculator here too: https://www.3cx.com/ordering/pricing/
Of course, as @leejor mentioned you can add as many extensions as you need so you can start with a lower SC and upgrade the license depending on usage later.
Reactions: Hostname
You're very welcome!
Let us know if you need anything else by posting a new thread!
Bluebox Global
