3cx SIP Generic configuration
eng5ald
I've had a issue with SIP Trunk (Generic) configuration for Incoming call
we have sip line with 100 number and we can't receiving call (incoming) , and for outgoing call is working fine
ProductProfessional Annual
Version Number16.0.493
we make configuration for our SIP line with this steps :
1- we go to SIP Trunk
2- add SIP Trunk
3- select country we select Generic
4- select provider in your country we select Generic SIP Trunk
5- Main Trunk No we add our main number without (area code and country code)
for Trunk Details steps we add the IP for out SIP Line in (Gateway Hostname / Outbound Proxy )
for Authentication type we select don not require - IP Based
we make the outgoing rules and incoming rules
Ok next step is to look at your logs, and see if the call even reaches the PBX:
1. Activity Log > Settings > Verbose Mode
2. Restart services
3. Make a test call and see if it appears in the logs
travislogixal
