3cx SIP Notify to Yealink 54W
Goga
Titanium Partner
I am looking for solution where 3cx can send SIP NOTIFY message to Yealink 54W IP phone whenever some make emergency call . Flash message on IP phone that "Emergency number 9XX is dialed from Ext 4XX".
As I see Yealink do support SIP NOTIFY through XML config where it flash message.
Any idea how can we config this without using 3cx API .
We place a call to an extension or ring group when this happens, as well as a chat AND an email to specified email addresses.
Thank for your reply , I know about this option but would like to know if there is way to FLASH message on IP Phone whensome dial emergency number using SIP Notify.
Just curious, when I select a ring group, is the message played only at the first to answer the ringgroup, or is it played to all the users in the group?
If you send it to a paging group it will automatically answer everyones IP Phone and broadcast the message.
If it is a normal ring group call then the 1st person that picks up will hear the message.
Thank you, all clear for me!
Reactions: NicholasP_3CX
Finatra.us
