3CX Softphone via Intune
twolf2286
We are wanting to install the 3CX app via Intune. Does anyone know if it is possible to supply the config data without the user having to sign into the web client to provision the app? Like update a txt document with the config data or something?
I'm looking for a solution too...
For security reasons an authenticated user will need to provision the application.
Ok for that, but is there a way to prepare configuration with at least 3CX instance url. So the user only has to click on "MS365" (in our case), or enter credentials that he would know more easyli than the full URL and port of the instance?
When using the Windows App, user is not supposed to know the webclient.
I am looking at this too. I want to deploy it via Intune but the MS Store app seems limited in what configurations it can take. Anyone has a solution to it?
Graham Robertson
