- Joined
- Oct 10, 2021
- Messages
- 1
- Reaction score
- 0
Hi, I'm new at 3cx.
I've a fresh install of 3cx with just a smartphone and a laptop (for now).
The purpouse of this install is to make calls trough my home analog pstn line.
I've a linksys SPA3000 (I know this model isnt supported by 3cx, But I alreaddy had this device at home).
I tried so many things to make it work, but i'm constantly getting stuck.
I found these following articles:
https://www.3cx.com/sip-phones/linksys-spa-921/
https://www.3cx.com/docs/manual/configuring-voip-gateway/
I did the following in 3cx:
- I created a user with extention 110
- I created an outbound rule with the gateway explained below
- Created a gateway with the ip of the SPA3000
This is the point where i got stuck.
There's a setting under the gateway settings called: route calls to->Main Trunc No
I don't know what to fill in there. I can't fill in 110 (the minimuum is 4 digits)
I can't get any further :/
some extra info:
3cx IP: 10.0.4.2
SPA3000 IP: 10.0.4.3
SPA3000 config: (de SPA3000 has 1(pstn) and 1(telephone-1) port)
I haven't configured the "pstn line" settings (for now, because I'm stuck)
I configured the following on the setting page "Line 1"
Proxy: 10.0.4.2
Subscriber info:
display name: SPA3000
Password <password given in 3cx gateway setting>
Auth ID: 10000 (from 3cx gateway setting)
User ID: 110
Use Auth ID: [YES]
Can someone help me further to set this up pls?
I'm a student in the IT, And i really want to start experimenting with 3cx.
My goal is to go for the 3cx certified badge after I'm used to this loveley system
some extra info:
3cx IP: 10.0.4.2
Proxy: 10.0.4.2
Subscriber info:
User ID: 110
Use Auth ID: [YES]
