- Joined
- Nov 14, 2019
- Messages
- 22
- Reaction score
- 1
we are using 3cx v 15.5 SP6 on Windows 10.
I'm trying to renew the SSL certificate with the help of the document (3cx.com/docs/renewing-ssl-certificate/)
In the document it shows the certificate name as pbx.mybusiness.com-crt.pem and key name as pbx.mybusiness.com-key.pem
Now when I go to program files/Bin/nginx/conf/instance1
I can see 3 files as it should and the names of certificate file is as it should be, pbx.mybusiness.com-crt.pem and for key file, pbx.mybusiness.com-key.pem
We are using a wildcard certificate and when I check the new certificate that has to be placed in 3cx,
certificate name is star_mybusiness.com and key certificate is star_mybusiness.com.key
When I check both files, it shows the file type as "security certificate" and "key file" instead of pem files.
What should I do?
Thank you.
What should I do?
Thank you.
