3cx Standard pro - SMS missing and Video calling
ronenba
trying to understand why i can't add sms and how to add video ability
went to messaging i add the facebook but seems i am missing SMS
i am using voip.ms with 3cx
Hi @ronenba
As a first step, please check your license edition in the portal.3cx.com.
Does it state Standard or PRO?
The SMS option is only available with PRO subscriptions.
Best regards,
Irina
You are welcome.
In regards to video ability, please refer to the 3CX Video Conferencing guide.
Video Conferencing is available with all subscriptions, for example, with a 3CX free (Standard), StartUp free, or StartUp PRO subscription it is a maximum of 25 participants.
Best regards,
Irina
thank you i will
You are welcome and let us know if you require any further help.
Best regards,
Irina
i do have another issue, i set up the PBX, trying to setup grandstream 2602P, i setup the extension ( or at least i think i did right) getting on the phone error "the number doesn't match the dial plan"
where do i get the configuration for a sip phone?
and how to i address this issue with match dial plan?
Hi @ronenba
Supported phone models are listed on our website and you can access the list and guides from here.
You can refer to our Support, Help, and Documentation page for more details.
We recommend obtaining support with the setting up and configuration of your system via the 3CX reseller.
Best regards,
Irina
asandris
