3CX StartUP - Flowroute Support?
CRC
Flowroute is listed as 'Supported' and 'Hosted By 3CX Support', but is not yet available to provision in StartUP. This is the only thing holding me back right now from launching a new campaign to recommend all my hosted customers move to the cloud. Is this going to happen in the near future?
It will come in update 5... very soon
Reactions: CRC
They've updated their SIP providers list. flowroute is definitely on it so fingers crossed it comes by September.
I might have to end up porting my numbers from VoIP.ms over to flowroute.
there are a few tech issues flowroute needs to be before they can be added to startup. You can certainly flag it with them to have them give it more priority...
They're listed under "Supported Providers" which states:
Supported Providers​
Supported Providers are tested against 3CX Hosted and on-premise installations. Compatible with 3CX in all "installation modes", including StartUP.
So once official version of StartUP is rolled out, we can or still cannot use flowroute?
Thanks.
Check your StartUp tenant. Flowroute should be available for you now.
Awesome! Now the important question -- when will the official StartUP roll out?? :)
Edvard
