3CX stopped to receive calls
admined
SMB User
my system on prem with 8 PRO license was working flawlessly.
A few days ago incoming calls stopped working.
I called my SIP trunk provider and he says it's all fine.
Analyzing the logs i discovered some strange behavior:
1) when the call drops, I saw it in the "portal section" and the timer is still going on
2) in the event log I see this:
EventID 50029
Call from <sip:[email protected];user=phone>;tag=1c2121681930 to <sip:[email protected];user=phone> has been dropped as it was not acknowledged in time. Please verify configuration and ensure there are no connectivity issues.
I don't know where the system get this IPs:
10.39.31.20
10.39.31.142
They're not in my subnets, they aren't in the firewall. I really don't know where the system finds them.
I verified the firewall (pfsense) configuration, nat rules, I restored a working backup of PBX but I always get the same error.
Firewall check is GREEN
Outbound calls are working
I have the same problem, too.
Did you manage to solve it?
Just to clarify:
  1. You have also an PfSense as router in front of your 3CX 8 SC pro on-premise instance?
  2. You have also unknown subnets in you 3CX eventlog about incoming calls?
In any other case (andy maybe this / yours) - please describe in more detail about the used environment (3CX) and the problem. Also: which SIP provider is being used?
Complex scenario: Operator A's connectivity with a GNR 300 number works, while 15 numbers with Operator B have this problem.
Both Italian operators. The subnet is not present on any VLAN. Firewall Fortinet
@Allinone, perhaps a new thread in the main forum areas, with a clear description of your issue will help everyone provide better input.
Reactions: bitn2
VAYA
