- Joined
- Jul 3, 2011
- Messages
- 2
- Reaction score
- 0
Hello All,
in the 3CX network settings, "Static IP" is selected, and the fields related to the STUN server are disabled. Despite this and even though the STUN servers should not be tracking our IP address the system periodically reports our FQDN IP address as 74.248.19.11. As a result, our remote extensions are unable to access the PBX or receive calls. While restarting the 3CX services temporarily resolves the issue and ensures the correct (actual) IP address is reported but the problem recurs after a while. The firewall test completes successfully, showing no issues. Here is what we have tried so far:
To whom does the IP address 74.248.19.11 belong? Why are we experiencing this issue? I would appreciate your suggestions.
- We have updated it to Version 20.0 Update 10 (Build 1785 Release - AI 1.6.91). We experienced the same issue in the previous version as well.
- We migrated the system from a Windows server to a Linux server. (in case it has to do with the operating system)
- We enabled "KEEPALIVEENABLED" in the 3CX parameters and set the interval to 30 seconds.
- We set the UDP timeout on the router to 1800 seconds.
- To test our current internet connection, we moved the server to a different location and used a different IP address; however, the same issue persisted, and the system again reported the IP address as 74.248.19.11.
