3CX STUN
KhaledQuenawy
if my 3CX server don't have static ip ... so all my remote ip phones which connect with STUN method ... if the ip of 3CX change ( because it is dynamic one ) how much time should the remote ip phone take to reconnect again ,,, long or short one so the users don't affected
This is not a way to use 3cx or only for testing period, no more, you need a static IP
Here in Saudi arabia it cost 400 USD per month for 1 static ip ...
Standard or Pro license - max 6 hrs for the 3CX dns to be updated
Enterprise license is 10 mins.
Waouaw incredible one ip adress cost a lot, more than petrol :(
could it be possiblefor you to host 3cx in google cloud or amazon S3 and have only a SBC on local side, in this case you have static IP given by hoster and SBC just need a private static ip
also with this scenario perhaps you don't need to bridge, just another SBC on second location
yes it is easy to do it in AWS amazon .. but how could i add my lines and gateway >>> could you give me your whatsapp number to contact easily with you please
Lines of course need to be in sip trunk format only, what kind of gateway do you use for now ?
I don't remember if patton can be used behind SBC
Do you need to keep the Patton ? Land lines you use are for Faxes ?
yes i want to keep using them to make outside call
KhaledQuenawy just deploy 3CX server in AWS cloud near Saudi Arabia and you are all set, no need to worry about paying 400US dollar you can host the entire server with static IP for that money for one year.
For the gateway, you will need to setup VPN between your on premise and AWS cloud. Is it possible for you to get a reliable VOIP service in Saudi Arabia, you can add one more SIP Trunk and and port your numbers across that will be the best way to go about your situation.
I've setup gateways across the 3CX SBC with success but wouldn't recommend it due it's un-supported status.
VPN if possible, Any decent hosting provider will offer hosted instances with a software firewall for VPN termination.
Then no requirement for STUN.
Dame24
