3CX - tel.search.ch CRM integration
ATT AG
HI
The number will be truncated by passing the parameter. Why ?
Can you tell me, what is wrong please ?
Abdullah
  • Telsearch.xml
    Telsearch.xml
3CX Console > Advanced > Contacts > Options, check the Match option. Set it to the number of digits you want it to send, or to "match exactly" to send the whole number.
Perfect, ti works. thanks.
lastshadow
