- Joined
- Aug 9, 2021
- Messages
- 84
- Reaction score
- 1
Hi sir,
I was generate the template and it was working before 3cx template was ping in the crm data was saving popup in crm was showing but now its not working even not sending request to createCall here is my template please guide me why its sudden stop working as it was working few days before
<?xml version="1.0"?>
<Crm xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" Country="US" Name="VT Latest" Version="1" SupportsEmojis="true">
<Number Prefix="AsIs" MaxLength="[MaxLength]" />
<Connection MaxConcurrentRequests="2" />
<Parameters>
<Parameter Name="ReportCallEnabled" Type="Boolean" Editor="String" Title="Enable Call Journaling" Default="False" />
<Parameter Name="Subject" Type="String" Parent="ReportCallEnabled" Editor="String" Title="Call Subject:" Default="3CX PhoneSystem Call" />
<Parameter Name="InboundCallText" Type="String" Parent="ReportCallEnabled" Editor="String" Title="Answered Inbound Call:" Default="[DateTime]: Answered incoming call from [Number] to [Agent] ([Duration])" />
<Parameter Name="MissedCallText" Type="String" Parent="ReportCallEnabled" Editor="String" Title="Missed Call:" Default="[DateTime]: Missed call from [Number] to [Agent]" />
<Parameter Name="OutboundCallText" Type="String" Parent="ReportCallEnabled" Editor="String" Title="Answered Outbound Call:" Default="[DateTime]: Answered outgoing call from [Agent] to [Number] ([Duration])" />
<Parameter Name="NotAnsweredOutboundCallText" Type="String" Parent="ReportCallEnabled" Editor="String" Title="Unanswered Outbound Call:" Default="[DateTime]: Unanswered outgoing call from [Agent] to [Number]" />
</Parameters>
<Authentication Type="No" />
<Scenarios>
<Scenario Id="" Type="REST" EntityId="ContactID" EntityOrder="[ContactID]">
<Request Url="http://54.38.120.117/crm/search?number=[Number]" MessagePasses="0" RequestEncoding="UrlEncoded" RequestType="Get" ResponseType="Json" />
<Rules>
<Rule Type="Any">contact.id</Rule>
</Rules>
<Variables>
<Variable Name="ContactID" Path="contact.id">
<Filter />
</Variable>
<Variable Name="FirstName" Path="contact.firstname">
<Filter />
</Variable>
<Variable Name="LastName" Path="contact.lastname">
<Filter />
</Variable>
<Variable Name="CompanyName" Path="contact.company">
<Filter />
</Variable>
<Variable Name="Email" Path="contact.email">
<Filter />
</Variable>
<Variable Name="PhoneBusiness" Path="contact.businessphone">
<Filter />
</Variable>
<Variable Name="PhoneMobile" Path="contact.mobilephone">
<Filter />
</Variable>
</Variables>
<Outputs AllowEmpty="false">
<Output Type="ContactID" Passes="0" Value="[ContactID]" />
<Output Type="FirstName" Passes="0" Value="[FirstName]" />
<Output Type="LastName" Passes="0" Value="[LastName]" />
<Output Type="CompanyName" Passes="0" Value="[CompanyName]" />
<Output Type="Email" Passes="0" Value="" />
<Output Type="PhoneBusiness" Passes="0" Value="[PhoneBusiness]" />
<Output Type="PhoneMobile" Passes="0" Value="[PhoneMobile]" />
<Output Type="ContactUrl" Passes="0" Value="http://54.38.120.117/crm/show?ContactID=[ContactID]" />
<Output Type="EntityId" Passes="0" Value="[ContactID]" />
<Output Type="EntityType" Passes="0" Value="Contacts" />
</Outputs>
</Scenario>
<Scenario Id="ReportCall" Type="REST" EntityId="ReportCall" EntityOrder="[ReportCall]">
<Request SkipIf="[IIf([ReportCallEnabled]!=True,True,[IIf([CallType]!=Inbound,True,False)])]" Url="http://54.38.120.117/crm/createCall?number=[Number]&agent=[Agent]&calldirection=[CallDirection]&calltype=[CallType]&duration=[Duration]&calltext=[InboundCallText]&endtime=[CallEndTimeLocal]&starttime=[CallStartTimeLocal]" MessagePasses="0" RequestContentType="application/json" RequestEncoding="Json" RequestType="Get" ResponseType="Json">
<PostValues Key="">
<Value Key="duration" Passes="1" Type="String">[Duration]</Value>
<Value Key="phone" Passes="1" Type="String">[Number]</Value>
<Value Key="calltype" Passes="1" Type="String">[CallType]</Value>
<Value Key="calldirection" Passes="1" Type="String">[CallDirection]</Value>
<Value Key="agent" Passes="1" Type="String">[Agent]</Value>
<Value Key="calltext" Passes="2" Type="String">[InboundCallText]</Value>
</PostValues>
</Request>
<Variables />
<Outputs Next="ReportCallMissed" AllowEmpty="true" />
</Scenario>
<Scenario Id="ReportCallMissed" Type="REST" EntityId="ReportCallMissed" EntityOrder="[ReportCallMissed]">
<Request SkipIf="[IIf([ReportCallEnabled]!=True,True,[IIf([CallType]!=Missed,True,False)])]" Url="http://54.38.120.117/crm/createCall?number=[Number]&agent=[Agent]&calldirection=[CallDirection]&calltype=[CallType]&duration=[Duration]&calltext=[MissedCallText]" MessagePasses="0" RequestContentType="application/json" RequestEncoding="Json" RequestType="Get" ResponseType="Json">
<PostValues Key="">
<Value Key="calltext" Passes="2" Type="String">[MissedCallText]</Value>
</PostValues>
</Request>
<Variables />
<Outputs Next="ReportCallOutbound" AllowEmpty="true" />
</Scenario>
<Scenario Id="ReportCallOutbound" Type="REST" EntityId="ReportCallOutbound" EntityOrder="[ReportCallOutbound]">
<Request SkipIf="[IIf([ReportCallEnabled]!=True,True,[IIf([CallType]!=Outbound,True,False)])]" Url="http://54.38.120.117/crm/createCall?number=[Number]&agent=[Agent]&calldirection=[CallDirection]&calltype=[CallType]&duration=[Duration]&calltext=[OutboundCallText]&endtime=[CallEndTimeLocal]&starttime=[CallStartTimeLocal]" MessagePasses="0" RequestContentType="application/json" RequestEncoding="Json" RequestType="Get" ResponseType="Json">
<PostValues Key="">
<Value Key="calltext" Passes="2" Type="String">[OutboundCallText]</Value>
</PostValues>
</Request>
<Variables />
<Outputs Next="ReportCallNotanswered" AllowEmpty="true" />
</Scenario>
<Scenario Id="ReportCallNotanswered" Type="REST" EntityId="ReportCallNotanswered" EntityOrder="[ReportCallNotanswered]">
<Request SkipIf="[IIf([ReportCallEnabled]!=True,True,[IIf([CallType]!=Notanswered,True,False)])]" Url="http://54.38.120.117/crm/createCall?number=[Number]&agent=[Agent]&calldirection=[CallDirection]&calltype=[CallType]&duration=[Duration]&calltext=[NotAnsweredOutboundCallText]" MessagePasses="0" RequestContentType="application/json" RequestEncoding="Json" RequestType="Get" ResponseType="Json">
<PostValues Key="">
<Value Key="calltext" Passes="2" Type="String">[NotAnsweredOutboundCallText]</Value>
</PostValues>
</Request>
<Variables />
<Outputs Next="" AllowEmpty="true" />
</Scenario>
</Scenarios>
</Crm>
<Parameters>
</Parameters>
<Scenarios>
<Rules>
</Rules>
<Variables>
<Filter />
</Variable>
<Filter />
</Variable>
<Filter />
</Variable>
<Filter />
</Variable>
<Filter />
</Variable>
<Filter />
</Variable>
<Filter />
</Variable>
</Variables>
</Outputs>
</Scenario>
<PostValues Key="">
</PostValues>
</Request>
<Variables />
</Scenario>
<PostValues Key="">
</PostValues>
</Request>
<Variables />
</Scenario>
<PostValues Key="">
</PostValues>
</Request>
<Variables />
</Scenario>
<PostValues Key="">
</PostValues>
</Request>
<Variables />
</Scenario>
</Scenarios>
</Crm>
