3CX update to V18 on Raspberry Pi
dekwa
I just got the message saying there was an upgrade available for my 3CX v16 installed o,n a Raspbeery Pi.
As this is a test device, I can play with it, so I wanted to upgrade.
It didn't work.
I've attached the log file.
it appears I can't connect to a certain library. is this related to the Pi install, or something else?
Looking at the log, the server can not reach ftp.halifax.rwth-aachen.de
It is returning the correct IP so are you restricting access to certain fqdn ?
not that I'm aware of...
@dekwa
Try the following:
1. SSH to the Raspberry pi
2. navigate to
Code:
/etc/apt/sources.list.d
3. move everything other that 3cxpbx.list and 3cxpbx-testing.list out of this directory.
4. run
Code:
sudo apt update
5. Try upgrading again
Note: You can delete the moved files once you've confirmed the upgrade is successful and everything is in order.
I managed to mess something up entirely and the pi SSH password isn't what it's supposed to be..
oh well...
Reinstalling it...
laranicole.lucus
