3CX V16.x IP Phone Firmware Location...?
JCLloyd
Forum User
I have all my Yealink T48G IP phones red flagged as needing firmware updates, as my system is among those that auto-upgraded from v15.5 to v16.0. I am just not typing in the correct verbiage to find the page with the new FW version. Can someone help me out with a URL? My phones are currently on v35.83.0.55, and that is where I keep ending up.
I am still checking to see if anything is not functioning, and I so far have only seen the FW issue and the need to convert recordings.
You should be able to select the phone under Phones, and click on firmware.
If this does not work, can you see the firmware updates if you go to Updates and then do the above.
My error... v35.83.0.60 is waiting. I could have sworn I saw v35.83.0.55... Time for more caffeine... is less... (:>)
Reactions: JCLloyd
The firmware files for the DECT phones need to be downloaded directly from the Yealink Web site:
https://www.yealink.com/products_48.html
It's perfectly described in the Firmware Upgrade of Yealink DECT guide.
But these are still the "old" ones.
E.g. all T2x, T4x and T5x firmwares are xx.83.0.55 while the "new" firmware are upgraded to xx.83.0.60 and xx.84.0.35.
https://www.3cx.com/support/phone-firmwares/
Or must we wait for Yealink to upgrade the DECT sets?
Hi complex1,
Please read my post carefully.
The question was "Where can I find the new firmware for the Yealink W52P, W53P and W56P DECT phones?". DECT phones and not the standalone desk-phones.
For the standalone desk-phones (E.g. all T1x, T2x, T4x and T5x models) you don't need to go to Yealink website. All supported firmware versions for the standalone desk-phones are listed in the Phone Firmware page.
IWalter
