- Joined
- May 7, 2019
- Messages
- 7
- Reaction score
- 0
Zoho integration not working after v16 upgrade, I'm getting this error.
Unknown function: IIf
Started scenario with empty id
Started Auth
Request text: https://accounts.zoho.com/oauth/v2/token
Request form value refresh_token set to
Request form value grant_type set to refresh_token
Request form value client_id set to
Request form value client_secret set to
Response text: {"access_token":"","expires_in_sec":3600,"api_domain":"https://www.zohoapis.com","token_type":"Bearer","expires_in":3600000}
Response finished
Variable AccessToken set to
Variable ApiDomain set to https://www.zohoapis.com
Finished Auth
System.ArgumentException: Unknown function: IIf
at TcxLexicalParser.LexEvaluator.ProcessInt(FunctionElement functionElement, IValueManager valueManager)
at CrmIntegration.EscapedExpressionEvaluator.ParseExpression(String expression, Boolean asExpression, IValueManager customManager)
at CrmIntegration.ScenarioProcessorBase.ProcessRequest(ScenarioRequest request, IValueManager customManager, HttpClient client, CancellationToken token)
at CrmIntegration.ScenarioProcessorBase.ProcessScenario(ProtocolScenario scenario, IValueManager customManager, CancellationToken token)
at CrmIntegration.ScenarioProcessorBase.Execute(ProtocolScenario scenario, CancellationToken token)
at CrmIntegration.CrmProcessor.GetContactInfoFromCrm(String contactNumber, String destinationEmail, Boolean createIfNotFound, CancellationToken token)
Thank you
Started Auth
Response finished
Finished Auth
Thank you
