Solved 3CX v20: Best Practice for Forwarding Calls for a Former Employee
TheVoice
Hi all,
In 3CX v20, what is the correct way to forward all external calls for a user that has left the company to another extension?
It appears that DIDs are now associated directly with an extension, and there is no longer a separate inbound rule destination like in v18. Under the user’s Forwarding Rules (Available status), I only see “Unanswered” and “Busy or Not Registered,” and there doesn’t seem to be a way to force the extension status from the admin console.
If a user has left the company and we want all inbound external calls (DID) to go to a different extension immediately (no ringing the old extension first), is the proper method:
  • Reassign the DID to the new extension?
  • Use forwarding rules on the old extension?
  • Something else?
Looking for best practice in v20.
Thanks in advance.
The best option is to reassign the DID to another extension, yes.
To forward calls, you can set this under the " Busy or Not Registered section to forward to another extension but the former option is best.
Great - thank you!
Reactions: Charles_3CX
