3CX V20 Custom FQDN
Sovuthy.net
Gold Partner
Dear 3CX Teams,
Regarding to my 3cx, I would like to customize FQND, first I tried to backup using command:
sudo -u phonesystem 3CXBackupCmd --file=partial_pbx_backup.zip --options=CH --log=/var/tmp/pbx_backup_cmd.log
Then I make reset 3cx by this command:
sudo /usr/sbin/3CXWizard --cleanup
After that, upload old backup file to 3cx, but not working like below
So relate to this issue, how we can check?
Best Regard
Sovuthy
The backup contains the FQDN so you cannot change the FQDN while restoring a backup. You would need to release the FQDN from your subscription and re-install the PBX from scratch.
Dear NicholasP_3CX,
Thank you so much for your information. I followed by your guide work well.
Best Regard
Sovuthy
KylieWilderman
