3CX v20 - Registered Phones
robbiederby
SOHO User
Is there any way of seeing at a glance the extensions that are registered via the 3CX app on iPhone and Android phones? When I check the phone section I can only see extensions registered are via the Windows app and physical desk and dect phones.
Rob
If you see their extension in green in the Users section but they have no phone registered, then the app is connected and Push is registered.
OR, the user may have enabled "Ring my mobile simultaneously", which also turns the user to green as it kinda "fakes" a registration.
Reactions: SweetAction
I think they show in the phones list while/near when they’re being used.
In the Phones section of the PBX you are able to see the list of the current registered extension and their endpoints.
ARKC
